ArchiMate 4.0: A practical guide
ArchiMate is a standardized language for describing enterprise architecture: how an organization’s goals, people, processes, information, applications, technology, and change initiatives relate. It helps teams build consistent models and communicate different parts of an enterprise without treating one diagram as a complete picture of reality. The Open Group released the ArchiMate 4 Specification in 2026.
This guide focuses on using the language in practice. For exact element definitions, permitted relationships, and notation, use the official specification and a tool that explicitly supports ArchiMate 4.
1. What ArchiMate models
A useful way to think about a model is as a set of connected facts:
  • Elements represent things such as a business actor, application component, process, data object, goal, or project.
  • Relationships show how those things connect: for example, who performs a process, what information it accesses, or which requirement a project addresses.
  • Views select and arrange a subset of the model to answer a particular audience’s question.
The aim is not to draw every detail. It is to make a particular concern—such as a transformation, a system dependency, or a capability gap—clear enough to discuss and act on.
2. ArchiMate 4’s domains
Version 4 organizes the language into domains, replacing the familiar “layers” terminology. Business, Application, and Technology remain, but they are domains rather than a prescribed hierarchy. The change is intended to avoid implying that business must always sit above applications, which must always sit above infrastructure.
The main domains are:
  • Common: Shared concepts, such as roles, collaborations, locations, groupings, and paths.
  • Business: Organizational actors and roles, products, business objects, and business-facing behavior.
  • Application: Applications and application-facing structures and behavior.
  • Technology: Technology infrastructure and physical elements.
  • Strategy: Strategic direction and resources, including capabilities, courses of action, and resources.
  • Motivation: The reasons and desired outcomes behind architecture decisions, such as stakeholders, drivers, goals, requirements, and assessments.
  • Implementation and Migration: The work and transition states used to move from current to target architecture, including work packages, deliverables, plateaus, and migration planning.
The domains help organize the language; they do not dictate how an enterprise must be structured. A well-chosen view can cross several domains.
3. Core modeling ideas
Structure, behavior, and things acted on
A common modeling pattern is:
  • Active structure: who or what performs behavior—such as a role, actor, application component, or device.
  • Behavior: what is done—such as a process, function, event, or service.
  • Passive structure: what behavior uses or changes—such as a business object, data object, or material.
For example: a Customer Service Representative performs Resolve Customer Request, which accesses a Customer Record.
Behavior is no longer tied to a domain-specific type
One notable ArchiMate 4 change is that behavior concepts such as Process, Function, Event, and Service are shared across domains rather than being split into separate business, application, and technology versions. The performer and surrounding context show where the behavior belongs.
Use Process when sequence or a result matters; use Function when grouping behavior by purpose, capability, or another organizing criterion. Use Service for behavior made available to a consumer. The same service concept can describe a customer-facing service or a technical service—the model’s context clarifies which.
ArchiMate process models are generally high-level architecture descriptions, not detailed workflow specifications. For detailed activity sequences, teams typically use a process-design notation such as BPMN.
Relationships carry much of the meaning
An element’s type alone rarely tells the whole story. Relationships express facts such as:
  • A role performs a process.
  • A process accesses a data object.
  • A behavior realizes a service.
  • A component serves another element.
  • A requirement is realized by a deliverable.
  • A project realizes a target change.
Use the relationship that expresses the actual architectural meaning, not merely the one that makes a diagram look connected. Check your modeling tool or the specification for the exact relationship rules.
Version 4 also introduces relationship multiplicity, which can express lower and upper bounds on the number of related instances where that precision matters—for example, specifying that a service must be realized by at least one process.
4. A running example: online order fulfillment
Suppose a retailer wants to improve online order fulfillment. Start with the concern: What must change to reduce order delays while preserving accurate inventory?
A compact model could include:
  • Motivation: Goal — Reduce order delays; Requirement — Inventory availability must be current enough to support order promises.
  • Strategy: Capability — Order Fulfillment; Course of Action — Introduce near-real-time inventory updates.
  • Business: Customer, Order Management role, and the Fulfill Order process.
  • Application: Order Management application, Inventory service, and Order data object.
  • Technology: Cloud platform and messaging infrastructure supporting the applications.
  • Implementation and Migration: Work Package — Connect warehouse inventory feeds; Deliverable — Inventory integration; Plateau — Target fulfillment architecture.
Then connect only the relationships needed to explain the decision:
  1. The Order Management role performs Fulfill Order.
  2. Fulfill Order accesses Order data and Inventory data.
  3. The Inventory service provides inventory information to the order process or application.
  4. The Inventory integration deliverable realizes the requirement for current inventory.
  5. The work package delivers that integration and moves the organization toward the target plateau.
This is an architecture-level example, not a prescription for a specific product or implementation. A detailed integration design would need more information about interfaces, data ownership, security, and operational requirements.
5. Common use cases
Use case Question the model helps answer Useful content
Application portfolio Which business capabilities depend on which applications? Capabilities, applications, services, relationships
Digital transformation What changes between current and target states? Goals, requirements, work packages, deliverables, plateaus
Impact analysis What could be affected if an application or data source changes? Dependencies across processes, services, applications, and data
Cloud or platform planning Which business services depend on which technology? Services, application components, nodes, networks, paths
Operating-model design Who performs important work, and where are responsibilities unclear? Actors, roles, collaborations, processes, services
Governance and compliance Which goals and requirements are addressed by which changes? Stakeholders, requirements, assessments, deliverables, projects
ArchiMate is useful when a concern crosses organizational and technical boundaries. It is less suitable as a substitute for detailed process execution models, data schemas, network configurations, or code-level designs.
6. A practical modeling workflow
  1. Name the decision or concern. For example: “Which applications are affected by the proposed customer-data change?”
  2. Choose the audience and view. Executives may need capabilities and outcomes; delivery teams may need applications, data, and work packages.
  3. Set the scope. Identify the organization, time horizon, and current, target, or transition state.
  4. Add only relevant elements. Start with the elements required to answer the question; expand the model only when a real dependency needs to be shown.
  5. Connect elements with meaningful relationships. Avoid decorative arrows or relationships chosen simply to force a connection.
  6. Check completeness and consistency. Look for unsupported claims, missing owners, unclear boundaries, and unlinked requirements or deliverables.
  7. Validate with people who know the reality. A model is a structured representation of architecture, not proof that the architecture is implemented as drawn.
  8. Maintain it when decisions or systems change. An outdated model can mislead more than a deliberately limited one.
A useful quality test: can a reader identify the model’s purpose, scope, assumptions, and important dependencies without needing the author to explain every symbol?
7. Moving from ArchiMate 3.2 to 4.0
Existing ArchiMate practitioners do not need to start from scratch, but they should check how their tools and repositories handle the vocabulary changes. The familiar business, application, and technology divisions remain as domains, and core modeling principles continue.
Among the concepts removed in the transition are Business Interaction, Application Interaction, Technology Interaction, Representation, Contract, Constraint, and Gap. The cited migration guidance describes alternatives such as modeling interactions with Process and participants, representing contracts as Business Objects, treating constraints as Requirements, and using Assessments to describe differences between architecture states represented by Plateaus. Confirm the appropriate mapping for your model and tool rather than mechanically replacing every old element.
Before migrating a repository:
  • Keep an untouched backup of the original model.
  • Check whether your modeling tool supports ArchiMate 4 import, export, and validation.
  • Test the conversion on a representative subset.
  • Review each converted element and relationship with an architect who understands its intended meaning.
  • Record any local conventions used to preserve distinctions that matter to your organization.
8. Can AI help?
Yes—as an assistant for drafting and analysis, not as the authority on the architecture. AI can help turn notes into candidate elements, suggest a first-pass view, summarize dependencies, identify apparent missing links, or explain a model to different audiences. These are practical uses of general AI, not a special ArchiMate 4 feature.
A cautious workflow is:
  1. Give the AI a clearly scoped concern and a small set of verified facts.
  2. Ask for a candidate model: elements, relationships, assumptions, and unresolved questions.
  3. Check every proposed element and relationship against the ArchiMate 4 specification and your modeling tool.
  4. Validate the model with system owners, business stakeholders, and architects.
  5. Keep confidential or regulated information out of AI tools unless your organization has approved the tool and data handling for that use.
AI can invent systems, owners, dependencies, or requirements that sound plausible. Treat generated content as a draft; do not let it silently become the system of record. Where possible, separate verified facts from assumptions and link model elements to authoritative inventories, decisions, or documentation.
9. Frequent mistakes to avoid
  • Trying to model everything: A model should serve a concern, not become an indiscriminate inventory.
  • Confusing a diagram with the repository: A view is one presentation of selected model content.
  • Treating domains as a mandatory hierarchy: ArchiMate 4 domains organize concepts; they do not prescribe a universal business-to-technology stack.
  • Using generic behavior elements without context: Since behavior is shared across domains, the performer and relationships need to make its role clear.
  • Using ArchiMate for detailed design: Use specialized notations where the architecture question requires implementation-level detail.
  • Treating AI output as verified: Generated relationships are hypotheses until people and evidence confirm them.
A concise rule of thumb
Model why a change matters, what the enterprise needs to do, who or what performs the behavior, which information and technology it depends on, and how the organization moves toward the target. Keep the model as small as possible while still answering the decision-maker’s question.
