ArchiMate is a visual modeling language for describing an enterprise’s structure, behavior, and change. A useful model helps people understand how business goals connect to applications and technology—and supports clearer decisions. The practices below turn the infographic’s seven principles into a practical workflow.
1. Start with stakeholder concerns
Before drawing anything, establish why the model is being created and who will use it. A model intended to support a technology migration will differ from one intended to explain a business capability or assess a proposed change.
Clarify:
Purpose: What decision, analysis, or communication should the model support?
Audience: Who needs to understand or act on it?
Scope: Which organization, processes, systems, locations, or time period are included?
Questions: What does the audience need to learn from the model?
Level of detail: What must be shown—and what can be left out?
Write down the scope and intended use before modeling. This helps prevent a diagram from becoming an exhaustive inventory that is difficult to read but does not answer a clear question.
2. Choose the right viewpoint
A viewpoint defines how a model is organized for a particular concern or audience. The same enterprise can be represented in different ways, each emphasizing different parts of the architecture.
For example:
A business-focused view might show capabilities, services, processes, and organizational roles.
An application-focused view might show application components, application services, and the business processes they support.
A technology-focused view might show infrastructure, platforms, and the applications deployed on them.
A change-focused view might compare current and target states, transitions, or implementation dependencies.
Choose the viewpoint by asking: What relationship or decision should be easiest to see? Include only the elements that help answer that question. If a diagram needs to serve distinct audiences, create several coordinated views rather than forcing every concern into one crowded picture.
3. Keep models focused
Each diagram should have a clear message. Include only elements relevant to its purpose and scope, and avoid adding detail just because it is available.
A focused model:
Uses a descriptive title and, where helpful, a short statement of purpose.
Keeps the number of concepts and relationships manageable.
Highlights important flows, dependencies, or ownership.
Separates different concerns into linked diagrams when needed.
Distinguishes what is known from what is assumed or still to be confirmed.
A model can be accurate yet still be ineffective if its key point is hard to find. Consider whether someone from the intended audience can identify the main takeaway quickly.
4. Use ArchiMate concepts consistently
Use ArchiMate concepts according to their intended meanings. The infographic highlights three broad layers:
Business: The people, roles, processes, functions, services, and other elements involved in delivering business value.
Application: The applications and application services that support business activity.
Technology: The infrastructure, platforms, and technology services that support applications.
Choose element types that match what you are describing, and use relationships consistently. For instance, distinguish a service offered by an element from a dependency between elements; do not use arrows merely as visual connectors.
Consistency also applies to naming and notation. Agree on conventions for names, abbreviations, colors, labels, and relationship direction. Use colors to reinforce meaning only when the legend explains them; do not rely on color alone to convey essential information.
5. Connect business, application, and technology layers
A central benefit of enterprise architecture is showing how different parts of the enterprise relate. Make traceability visible: readers should be able to follow how business needs connect to applications and the technology that supports them.
A practical chain might show:
A business capability or process that addresses a need.
The application service or application component that supports it.
The technology services or infrastructure on which the application depends.
Not every model needs to show every layer. Add cross-layer relationships when they help answer the question at hand—for example, assessing which business services may be affected by a platform change. Verify that each connection represents a real relationship, not just a plausible one.
6. Validate and govern the model
Treat a model as an maintained architecture asset, not a one-time drawing. Validate both its correctness and its usefulness.
Review:
Consistency: Are element types and relationships used coherently?
Accuracy: Do the modeled structures reflect the agreed understanding of the enterprise?
Completeness for purpose: Does the model contain enough information to answer its intended questions?
Ownership: Who is responsible for reviewing and updating it?
Currency: When was it last checked, and what changes should trigger a review?
Where possible, use modeling tools or review checklists to identify notation errors and inconsistencies. Have relevant stakeholders confirm the parts they own or understand. Record assumptions, unresolved questions, and important decisions so readers can distinguish verified information from provisional content.
7. Reuse and communicate
Reuse established conventions, approved architecture elements, and existing models where they fit. Reuse improves consistency and reduces duplicate work, but copied material should be checked for relevance and accuracy before it is applied to a new context.
Make models easy to understand and discuss:
Use clear labels and a visible legend where needed.
Organize related elements so that relationships are easy to follow.
Provide a short explanation of the model’s purpose and scope.
Share it with the people who need to review or use it.
Capture feedback and update the model when the underlying architecture changes.
A diagram is often most valuable as a conversation aid. Use it to expose assumptions, clarify dependencies, and support decisions—not as a substitute for discussion or documentation when those are needed.
A practical workflow
Define the audience, purpose, scope, and questions.
Select a viewpoint that fits those needs.
Identify the relevant elements and relationships.
Model only the detail needed to answer the questions.
Check consistency and traceability across relevant layers.
Review the model with stakeholders and record unresolved assumptions.
Publish it with clear labels, ownership, and a review plan.
Revisit it when the enterprise or the decisions it supports change.
Effective ArchiMate models are not simply detailed diagrams. They are focused, consistent, validated, and understandable representations that help people make better-informed decisions.
