ArchiMate for Beginners — A Practical Guide
Tooling focus: Visual Paradigm (ArchiMate) + AI & VPasCode
1. What ArchiMate Is (and Why You Should Care)
ArchiMate is an open modelling language for enterprise architecture, maintained by The Open Group. If UML is a language for describing software designs, ArchiMate is a language for describing how an entire enterprise works — from business strategy down to the servers that run it.
Its core promise is the realization chain: everything in the enterprise can be described as something delivering value to something above it.
Why beginners like it:
  • Small vocabulary (~60 element types, but you only need ~15 to start)
  • Visually consistent notation (colours communicate meaning instantly)
  • Forces you to connect the dots between strategy and IT — no “orphan” boxes
  • Industry standard, so your diagrams are readable by other architects and recruiters
What ArchiMate is NOT:
  • Not a process-notation like BPMN (ArchiMate shows that a process exists and what it serves; BPMN shows how the process runs)
  • Not a software design notation like UML (ArchiMate’s application layer is coarse-grained)
  • Not a methodology (it’s a language — TOGAF, for example, is a method that uses ArchiMate)
2. The Grammar of ArchiMate: Three Dimensions
Every ArchiMate model is defined along three axes. Understand these three and you understand the language.
2.1 Aspect (what question am I answering?)
Aspect Question it answers Typical elements
Active Structure Who / what performs behaviour? Actor, Role, Application Component, Node
Behaviour What activity happens? Process, Function, Service, Event
Passive Structure What information/object is acted on? Business Object, Data Object, Artifact
Rule of thumb for beginners: Active structures are shaded solid boxes, behaviour is rounded, passive structure is a rectangle with a folded corner or plain box.
2.2 Layer (at what altitude?)
Layer Contents Colour convention
Strategy Capabilities, courses of action, value streams, resources Purple
Motivation Stakeholders, drivers, goals, requirements, principles Pink / lilac
Business Actors, roles, processes, services, business objects Yellow / orange
Application Components, services, interfaces, data objects Cyan / teal
Technology Nodes, devices, system software, networks, artifacts Green
Physical Equipment, facilities, distribution networks Green (darker)
Implementation & Migration Work packages, deliverables, plateaus, gaps Magenta
2.3 Service Orientation
Everything delivers a service to the layer above. This gives you the single most important sentence in ArchiMate:
A lower layer serves the layer above it, and realizes it from below.
Technology serves Application serves Business serves Strategy.
3. Essential Element Types
You can go a very long way with this shortlist.
Motivation Layer
  • Stakeholder — a party with an interest (CFO, Customer, Regulator)
  • Driver — the external or internal pressure (“Rising delivery costs”)
  • Assessment — the analysis of that driver (“Manual order handling is slow”)
  • Goal — the desired end state (“Reduce handling time by 40%”)
  • Outcome — the measurable result (“Average order handling = 2 min”)
  • Requirement — the concrete must-have (“Order entry must be fully digital”)
  • Constraint — a restriction (“Must comply with GDPR”)
  • Principle — a standing rule (“Data is entered once at source”)
Business Layer
  • Business Actor — an organisational entity (“Customer”, “Retail Bank”)
  • Business Role — a responsibility played by an actor (“Warehouse Picker”)
  • Business Collaboration — a temporary partnership of roles
  • Business Process — an ordered sequence of behaviour that achieves a result
  • Business Function — a grouping of behaviour internally driven (not customer-triggered)
  • Business Service — the external-facing service a process exposes
  • Business Object — business information (“Order”, “Invoice”)
  • Business Event — something that happens in the business (“Order Placed”)
  • Business Interface / Product / Contract — the customer-facing edge
Application Layer
  • Application Component — a deployable, encapsulated unit (“CRM System”)
  • Application Service — behaviour exposed to consumers (“Customer Lookup Service”)
  • Application Interface — the access channel (“REST API v2”)
  • Application Data Object — structured data (“Customer Record”)
  • Application Collaboration / Event
Technology Layer
  • Node — a computational or hosting resource (“Cloud Region”, “Server”)
  • Device — physical hardware (“Scanner”)
  • System Software — OS, runtime, DBMS
  • Technology Service — a platform service (“Object Storage”)
  • Communication Network / Path, Artifact (deployed file)
  • Work Package — a unit of change (“CRM Rollout Wave 1”)
  • Deliverable — the produced output (“Migrated Customer Data”)
  • Plateau — a stable state in time (“As-Is”, “Target State”)
  • Gap — the difference between plateaus
  • Implementation Event
Beginner tip: Never draw a Technology Device when you mean an Application Component. The most common beginner error is collapsing the application and technology layers into one.
4. The Relationships — Learn These Eight
Relationships are where beginners struggle, because ArchiMate has 11 and they look similar. Learn the eight that matter.
Relationship Notation Meaning Typical example
Composition filled diamond whole–part, strong Application Component ⬦ Application Interface
Aggregation hollow diamond grouping, weak part Business Actor ⬦ (aggregates) Business Role
Assignment line with filled ball end who performs what Business Role → Business Process
Realization dashed arrow, hollow tip A makes B real Business Process ⇢ Business Service
Serving line with open arrowhead A provides value to B Application Service → Business Service
Access dashed line with open arrow read / write / modify data Business Process ⇢ Business Object (write)
Triggering line with filled arrow temporal cause “Order Placed” → Validate Order
Flow line with filled arrow + solid line movement of info/material Pick & Pack → Ship Order
Two more, useful later: Influence (motivation elements affect each other) and Specialization (generalisation).
The Three-Question Test
When you’re unsure which relationship to use, ask:
  1. “Is one a part of the other?” → Composition / Aggregation
  2. “Is one responsible for doing the other?” → Assignment
  3. “Does one deliver value to the other?” → Realization (abstract output) or Serving (concrete consumer)
Common Mistakes to Avoid
❌ Wrong ✅ Right Why
Node → Serving → Application Component Node → Assignment → Application Component A node hosts, it doesn’t serve
Application Component → Serving → Business Object Application Component → Access → Business Object Components don’t touch data directly; behaviours do
Process → Realization → Goal, with no service layer Process ⇢ Business Service ⇢ Goal Insert the service as the intermediate contract
A Requirement → Realization → A Goal Requirement → Influence → Goal, or Goal → Realization → Requirement Goals realise requirements, not the reverse
Everything connected to everything One relationship per element pair Redundant edges kill readability
5. Viewpoints — Where Beginners Should Start
A viewpoint is a lens: a legally-restricted subset of element and relationship types chosen for a specific audience. ArchiMate 3.2 defines 27 of them. You will use maybe six.
Start here: Layered Architecture (a.k.a. Big Picture)
Audience: Executives, new team members
Purpose: show the whole realization chain in one page
@startuml
!include https://static.visual-paradigm.com/plantuml-stdlib/Archimate-PlantUML/master/Archimate.puml
skinparam vpDiagramType ArchiMateDiagram
skinparam defaultFontSize 14
skinparam defaultFontColor #333333
skinparam linetype ortho
remove @unlinked
top to bottom direction
title Layered Architecture Viewpoint - Online Retail Platform
together {
Grouping(motivation_layer, "Motivation Layer") {
  Motivation_Driver(d_omni, "Omnichannel Customer Expectation")
  Motivation_Goal(g_revenue, "Increase Online Revenue 20%")
  Motivation_Requirement(r_shop, "Provide 24/7 Self-Service Shopping")
Grouping(business_layer, "Business Layer") {
  Business_Process(bp_order, "Order Fulfilment")
  Business_Service(bs_sales, "Online Sales Service")
  Business_Actor(customer, "Customer")
Grouping(application_layer, "Application Layer") {
  Application_Component(ac_store, "Web Storefront")
  Application_Service(as_sales, "Checkout Service")
  Application_DataObject(do_order, "Order Record")
Grouping(technology_layer, "Technology & Physical Layer") {
  Technology_Node(tn_cloud, "Cloud Hosting Platform")
  Technology_Service(ts_compute, "Container Runtime")
Rel_Influence_Down(d_omni, g_revenue, "")
Rel_Influence_Down(g_revenue, r_shop, "")
Rel_Realization_Up(bs_sales, r_shop, "")
Rel_Serving_Up(bp_order, bs_sales, "")
Rel_Serving_Up(ac_store, bs_sales, "")
Rel_Realization_Up(ac_store, as_sales, "")
Rel_Access_Down(ac_store, do_order, "")
Rel_Serving_Up(ts_compute, ac_store, "")
Rel_Assignment_Up(tn_cloud, ts_compute, "")
Rel_Assignment_Up(customer, bp_order, "")
@enduml
The Six Viewpoints Worth Learning First
Viewpoint Layer Use it when…
Layered Architecture All You need the one-slide overview
Motivation Motivation Justifying a change to executives
Capability Map Strategy Structuring a business/IT portfolio
Business Process Cooperation Business Mapping an end-to-end journey and its hand-offs
Application Cooperation Application Showing how systems integrate
Technology / Technology Usage Technology Planning infrastructure and hosting
Worked Example: Business Process Cooperation
This viewpoint is your first “real” model — it shows processes triggering each other, roles assigned to them, and the objects they touch.
@startuml
remove @unlinked
title Business Process Cooperation - Order to Delivery
  Business_Role(clerk, "Sales Clerk")
  Business_Event(ev_paid, "Payment Received")
  Business_Process(p_validate, "Validate Order")
  Business_Process(p_pick, "Pick and Pack")
  Business_Process(p_ship, "Ship Order")
  Business_Object(o_order, "Order Record")
  Business_Object(o_shipment, "Shipment Record")
Rel_Assignment_Down(clerk, p_validate, "")
Rel_Assignment_Down(clerk, p_ship, "")
Rel_Triggering_Right(ev_paid, p_validate, "")
Rel_Triggering_Right(p_validate, p_pick, "")
Rel_Triggering_Right(p_pick, p_ship, "")
Rel_Access_Down(p_validate, o_order, "")
Rel_Access_Right(p_pick, o_order, "")
Rel_Flow_Right(p_pick, o_shipment, "")
Rel_Serving_Up(p_ship, customer, "")
@enduml
Notice the discipline: the Sales Clerk is assigned to processes (not “connected” to them), the event triggers the first process, processes trigger each other, and objects are accessed, never merely linked.
6. A Beginner’s Modelling Workflow
Follow this sequence and you’ll never produce a model that doesn’t hang together.
Step 1 — Write the one-sentence purpose.
“This model shows how the online order service is delivered and by which systems.”
If you can’t write it, you’re not ready to model.
Step 2 — Pick the viewpoint before the elements. The viewpoint tells you which element types are legal. Choosing elements first is how people end up with a “diagram” that mixes BPMN, UML and ArchiMate.
Step 3 — Start from Motivation, work downwards.
Driver → Assessment → Goal → Requirement → then into Business.
Step 4 — Model the business service, not the business process, first. Services are the stable contracts between layers. Processes are implementation and will change.
Step 5 — Layer by layer, enforce the connection rule. For every element you add, immediately add its relationship to the layer above or below. An element with no cross-layer relationship is a red flag.
Step 6 — Apply the 7±2 sanity check. A single diagram should read at a glance. If you have more than ~20 relationships, split into viewpoints rather than one mega-diagram.
Step 7 — Review with the three-question test (part-of / responsible-for / delivers-value) on every edge.
7. Tooling: Visual Paradigm ArchiMate
Visual Paradigm is one of the strongest ArchiMate tools because it ships the full ArchiMate 3.2 specification (all elements, all 27 viewpoints, correct notation) out of the box, rather than approximating the notation with generic shapes.
7.1 Getting Started
  1. New Project → choose ArchiMate as the model type (not “Blank project”). This seeds the metamodel so relationship rules are enforced.
  2. Open the ArchiMate palette — elements are grouped by layer, matching the spec.
  3. Pick a viewpoint diagram rather than a blank canvas: Modeling → ArchiMate → Viewpoint. Visual Paradigm will pre-filter the palette to only the legal element types for that viewpoint. This is the single biggest quality lever for a beginner.
7.2 Working Effectively in Visual Paradigm
Use the Model Repository, not just the canvas.
The repository is the real model; diagrams are views onto it. Drag a Business Actor from the repository onto three different diagrams — it’s one element, three views. Never re-create the same element on a new diagram; that creates duplicates and breaks traceability.
Let the relationship rules guide you.
When you drag a relationship between two elements, Visual Paradigm flags invalid combos. Pay attention — the ArchiMate metamodel’s rules are pedagogically excellent.
Use element numbering and the Model Element grid for QA.
Sort the grid by element type and look for elements with no relationships. Those are your modelling gaps.
Derive views with Analysis diagrams.
Rather than hand-drawing the same content three times, maintain one source model and generate the Layered / Motivation / Application views from it. Visual Paradigm’s Visual History and Traceability then link them.
Export for stakeholders.
Use PNG for slides, SVG for documentation, and the HTML report for a navigable model export. Never send .vpp files to non-modellers.
7.3 Visual Paradigm Anti-Patterns
Anti-pattern Fix
Drawing ArchiMate elements as generic rectangles with coloured fills Use the ArchiMate palette so shapes carry the correct semantics
Duplicating an element per diagram Drag from the Model Repository
One giant diagram with everything One diagram per viewpoint, linked by the model
Using free-form text on connectors Use the typed relationship from the palette
Mixing BPMN tasks into an ArchiMate Business Process Model the process in ArchiMate; link to a BPMN child diagram if detail is needed
8. AI + VPasCode: Modelling at Speed
This is where the workflow changes for beginners. The traditional bottleneck in ArchiMate is notation syntax and layout, not thinking. AI can absorb the syntax burden; you keep the judgement.
8.1 The Core Idea
ArchiMate has a clean textual representation. If you can describe the model in plain language, an AI assistant can generate the diagram code, and VPasCode can render and refine it — no manual shape-dragging.
The conversational loop:
Describe the model in business language → generate the diagram → review semantics → iterate (“add the payment system”, “this relationship should be assignment, not serving”) → export into your Visual Paradigm model for the formal repository.
8.2 Example: From Sentence to Diagram
Prompt to the AI:
“Model my customer onboarding process in ArchiMate Business Process Cooperation viewpoint: Digital Marketing captures leads, KYC Check validates identity, Sales Review approves, Core Banking creates the account. Compliance Officer performs KYC. Customer is served by the onboarding service.”
The AI returns diagram code you paste into VPasCode, which renders the model:
@startuml
title Business Process Cooperation - Customer Onboarding
  Business_Role(officer, "Compliance Officer")
  Business_Process(p_lead, "Capture Leads")
  Business_Process(p_kyc, "KYC Check")
  Business_Process(p_review, "Sales Review")
  Business_Process(p_open, "Open Account")
  Business_Service(s_onboard, "Customer Onboarding Service")
  Business_Object(o_kyc, "KYC File")
Rel_Triggering_Right(p_lead, p_kyc, "")
Rel_Triggering_Right(p_kyc, p_review, "")
Rel_Triggering_Right(p_review, p_open, "")
Rel_Assignment_Down(officer, p_kyc, "")
Rel_Access_Down(p_kyc, o_kyc, "")
Rel_Realization_Up(p_open, s_onboard, "")
Rel_Serving_Up(s_onboard, customer, "")
@enduml
Then you refine conversationally: “the Sales Review should also be assigned to a Relationship Manager role”, “add a Business Event ‘Application Submitted’ that triggers KYC”. Each iteration is seconds, not minutes.
8.3 Prompt Patterns That Work
Goal Prompt pattern
Bootstrap a model “Create a Layered Architecture viewpoint for a [domain] company. Show one driver, one goal, one business service, one application service, and one technology node, plus mandatory cross-layer relationships.”
Convert prose to model “From this paragraph, extract ArchiMate Motivation elements and their influence relationships. List as a table first, then draw.”
Validate semantics “Review this ArchiMate description and tell me which relationships are wrong per the metamodel, and why.”
Restructure “This diagram has 28 elements. Split it into an Application Cooperation view and a Technology view, keeping element identity consistent.”
Explain “Explain this ArchiMate diagram to a non-technical business sponsor in five sentences.”
8.4 Where AI Must Not Decide
Be explicit about keeping these human-owned — AI will confidently produce plausible nonsense:
  • Element identity. Is this one business service or two? Naming discipline is architecture, not text generation.
  • Abstraction level. AI tends to over-detail. Force consolidation.
  • Relationship semantics in ambiguous cases. Serving vs Realization is a modelling judgement with real downstream consequences.
  • Scope. What is outside the model is as important as what’s in it. AI never knows your boundaries.
  • The purpose sentence. Nobody else can write it.
8.5 Recommended Division of Labour
Activity Who
Choosing the viewpoint You
Naming elements consistently You (AI proposes drafts)
Drawing syntax and layout AI + VPasCode
Cross-layer completeness check AI, verified by you
Metamodel rule validation AI + Visual Paradigm
Abstraction and scope decisions You
Final repository hygiene, versioning, sign-off You in Visual Paradigm
9. Practical Exercise: Your First 90 Minutes
Do this in order — it’s deliberately structured so each step builds on the last.
Minutes 1–10 — Write the purpose.
Pick a system you know (a coffee shop’s ordering, your company’s expense claims). Write one sentence: “This model shows how X delivers Y to Z.”
Minutes 10–25 — Motivation only.
Model: 1 Stakeholder, 1 Driver, 1 Assessment, 1 Goal, 2 Requirements. Connect with Influence and Realization. Don’t add anything else.
Minutes 25–45 — Business layer.
Add 1 Actor, 2 Roles, 3 Processes, 2 Business Objects, 1 Business Service. Apply Assignment, Triggering, Access. Then one process ⇢ Realization ⇢ the Business Service.
Minutes 45–65 — Application layer.
Add 2 Application Components and 2 Application Services. Enforce: Application Service ⇢ Serving ⇢ Business Service. Application Component ⇢ Realization ⇢ Application Service.
Minutes 65–80 — Technology layer.
Add 1 Node and 1 Technology Service. Enforce: Technology Service ⇢ Serving ⇢ Application Component, and Node ⇢ Assignment ⇢ Technology Service.
Minutes 80–90 — Review.
Run the three-question test on every edge. Look for elements with only one relationship — those are usually lazily-placed fillers, not real architecture.
When you finish, you’ll have produced what most people take a full-day course to attempt, and more importantly you’ll have felt why ArchiMate’s constraints exist.
10. Cheat Sheet
The realization chain (memorise this):
Driver → Goal → Requirement → Business Service → Application Service → Technology Service
Layer colours: Motivation pink · Strategy purple · Business yellow · Application cyan · Technology green · Implementation magenta
Three relationship questions: part-of? · responsible-for? · delivers-value-to?
The five rules of a good ArchiMate model:
  1. Every element belongs to exactly one layer
  2. Every element connects across a layer boundary (no islands)
  3. Use the narrowest legal viewpoint, not the widest
  4. One relationship per element pair
  5. If it doesn’t fit on one screen, split the viewpoint
Top five beginner errors:
  1. Confusing Application and Technology layers
  2. Using Serving where Assignment is correct (Node → Component)
  3. Omitting the service layer between process and goal
  4. Treating ArchiMate as BPMN (drawing step-by-step flows)
  5. Modelling everything instead of modelling what the audience needs
Vocabulary you’ll hear: metamodel (the rules), viewpoint (a legal lens), view (a rendered diagram), repository (the single source model), plateau (a stable state in time), gap (difference between plateaus).
