ArchiMate tutorial for beginners with Visual Paradigm FREE online ArchiMate Tool
ArchiMate is a visual modeling language for showing how an organization’s business, applications, and technology fit together. The key is to model only what helps answer a particular question—not to draw the whole enterprise at once. A viewpoint sets the purpose and audience; a view is the resulting diagram.
1. Learn the core layers
  • Business: people, roles, processes, services, and information involved in the work.
  • Application: software components and the services they provide.
  • Technology: infrastructure—such as servers, devices, and networks—that runs the applications.
A model can connect these layers to trace how technology supports applications and how applications support business work.
2. Understand the basic building blocks
Think in terms of three questions:
  • Who or what performs work? An active structure element, such as a business role or application component.
  • What work happens? A behavior element, such as a process or function.
  • What does the work use or change? A passive structure element, such as a data object.
Then connect elements with relationships that express what you mean—for example, a role performs a process, an application supports a process, or a process accesses data. Choose relationships deliberately; a line without a clear meaning can make a diagram harder to interpret.
3. Build a small example: online order
Suppose a customer places an order:
  1. In the Business layer, model a Customer using the Place Order process.
  2. In the Application layer, model an Order System that supports that process.
  3. Add an Order Data object that the process or system uses.
  4. In the Technology layer, add a Cloud Platform that runs the Order System.
  5. Draw only the relationships needed to explain the flow from business activity to supporting software and infrastructure.
Use this as a conceptual sketch, and check each element and relationship against the notation supported by your modeling tool.
4. Start from a stakeholder’s question
Before drawing, write down who needs the diagram and what decision or concern it should address. For example, “Which applications support order processing?” calls for a focused view—not every server, team, and process in the company. Viewpoints help keep diagrams relevant to their audience.
5. Practice with a modeling tool
Create a new view, add a few labeled elements, connect them, and keep the diagram readable. The open-source tool Visual Paradigm Online is one FREE option for creating ArchiMate diagrams.
Beginner tips: Use plain-language labels, keep the first diagram small, and expand it only when a real question requires more detail. If the diagram is crowded, split it into separate views rather than shrinking everything onto one page.
